[postgis-devel] [PostGIS] #311: Rename postgis.sql to postgis-1.5.sql
PostGIS trac at osgeo.org
Fri Jan 15 02:22:48 PST 2010
  Reporter:  pramsey  |       Owner:  mcayland
      Type:  defect   |      Status:  reopened
  Priority:  medium   |   Milestone:  PostGIS 1.5.0
 Component:  postgis  |     Version:  trunk
Resolution:           |    Keywords:
Comment (by mcayland):
 From what people are reporting, it seems that the sed command is working
 correctly and "make install" now works.
 So could it just be a simple file permissions problem? Bear in mind that
 the build directories will have files owned by the currently logged in
 user, whereas in order for the backend to access the files under regress/
 00-regress-install then they must also be readable by the postgres Windows
 user (or whatever user was specified as part of the PostgreSQL install).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/311#comment:34>
