[postgis-devel] PostGIS 1.5 beta2
Nicklas Avén nicklas.aven at jordogskog.no
Fri Jan 15 04:06:44 PST 2010
you were rith agin Mark editing regress/postgis didn't work though because it was overwritten at the next run nut I hardcoded in regress/makefile like this
# Where we put our regression installation
#srcdir=$(shell pwd)
#REGRESS_INSTALLDIR=$(srcdir)/00-regress-install
REGRESS_INSTALLDIR= C:/utv/src/pg15/regress/00-regress-install
then it seems to work. I still have the usual problem with windoes newline. But it looks normal exept for that. /Nicklas
2010-01-15 Mark Cave-Ayland wrote:
Nicklas Avén wrote:
>> Sorry Mark, I'm too novice
>> where to do that change?
>> /Nicklas
>In the file regress/postgis.sql (it gets copied from postgis/postgis.sql
>when you invoke "make check").
>HTH,
>Mark.
>Mark Cave-Ayland - Senior Technical Architect
>PostgreSQL - PostGIS
>Sirius Corporation plc - control through freedom
>http://www.siriusit.co.uk
>t: +44 870 608 0063
>Sirius Labs: http://www.siriusit.co.uk/labs
>_______________________________________________
>postgis-devel mailing list
>postgis-devel at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20100115/2891ac2e/attachment.html>
