[postgis-devel] PostGIS 1.5 regression with GEOS 3.0.3
Paragon Corporation lr at pcorp.us
Fri Jan 15 04:50:28 PST 2010
I see it as
3.0 - has known bugs
3.1 - works well, but can leak memory, has more topological exceptions,
doesn't support all PostGIS 1.5 function (some will be disabled IFDEF
madness)
3.2 - (hopefully) works well with no memory leaks
Not that it matters though.
Thanks,
Regina
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Mark
Cave-Ayland
Sent: Friday, January 15, 2010 5:16 AM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] PostGIS 1.5 regression with GEOS 3.0.3
Kevin Neufeld wrote:
> +1 for 3.1.  Yes, it's been out for only a little while, but I also
> +see
> what Regina is saying.  If you want the latest and greatest functions
> from PostGIS, it stands to reason you'll need the latest and greatest
> supporting libraries.
> -- Kevin
+1 for 3.1, as I see the GEOS releases like this:
Otherwise people will keep reporting the same bugs against GEOS as they will
for the old versions, and so bumping the GEOS version should keep the bug
noise lower on the new release.
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect PostgreSQL - PostGIS Sirius
Corporation plc - control through freedom http://www.siriusit.co.uk
t: +44 870 608 0063
Sirius Labs: http://www.siriusit.co.uk/labs
postgis-devel mailing list
postgis-devel at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-devel
