[postgis-devel] [PostGIS] #318: 900913->4326 Transform
PostGIS trac at osgeo.org
Mon Jan 18 05:19:38 PST 2010
  Reporter:  pramsey  |       Owner:  mcayland
      Type:  defect   |      Status:  new
  Priority:  medium   |   Milestone:  PostGIS 1.4.1
 Component:  postgis  |     Version:  trunk
Resolution:           |    Keywords:
Comment (by mcayland):
 Unfortunately, without a database dump of the relevant tables then it is
 impossible for me to re-create this here. Can you extract a small set of
 geometries that will re-create the bug into a separate table and then
 provide a pg_dump file that I can use for testing?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/318#comment:12>
