[postgis-devel] [PostGIS] #387: ST_Transform decimal issue on Win32
PostGIS trac at osgeo.org
Mon Jan 18 09:36:46 PST 2010
  Reporter:  colivier  |       Owner:  pramsey
      Type:  defect    |      Status:  new
  Priority:  medium    |   Milestone:
 Component:  postgis   |     Version:  trunk
Resolution:            |    Keywords:  ST_Transform Win32 decimal
Comment (by pramsey):
 Are you pointing up a problem in transform or in output formatting? Does
 the problem manifest w/o transform? There is a datum shift from bessel to
 wgs84 which is probably the issue. Does the windows installation have a
 PROJDIR environment variable set, and a complete set of datum shift grids?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/387#comment:2>
