[postgis-devel] [PostGIS] #387: ST_Transform decimal issue on Win32
PostGIS trac at osgeo.org
Mon Jan 18 09:42:30 PST 2010
  Reporter:  colivier  |       Owner:  pramsey
      Type:  defect    |      Status:  new
  Priority:  medium    |   Milestone:
 Component:  postgis   |     Version:  trunk
Resolution:            |    Keywords:  ST_Transform Win32 decimal
Comment (by mcayland):
 Also see the SetPROJ4LibPath() function in lwgeom_transform.c; the Windows
 installation adds a PROJ search path entry which should get used first.
 Maybe this clashes with other PROJ.4 installations in C:\PROJ?
 Incidentally, I also see a bug here: the hard-coded path to the search
 path entry should probably be changed as per the new directory-versioning
 install.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/387#comment:4>
