[postgis-devel] PostGIS 1.5 beta2
Paul Ramsey pramsey at cleverelephant.ca
Wed Jan 20 15:36:15 PST 2010
Great, commit it and close ticket #311, noting the revision of your commit.
Thanks!
P
On Wed, Jan 20, 2010 at 12:28 PM, Nicklas Avén
<nicklas.aven at jordogskog.no> wrote:
> Ok, it seems to work :-)
> new patch attached
> But it didn't work at first, and I don't know what I changed ( I downloaded
> fresh config.ac and regress/makefile.in)
> But it works to me now
> /Nicklas
> 2010-01-20 Mark Cave-Ayland wrote:
> Nicklas Avén wrote:
>>> Mark
>>> After a lot of trial and error I have a patch that works for me in MingW
>>> first I tried to pass "pwd -W" as is, to makefile.in and let it make
>>> the path from there. I thought that was what you meant. But I didn't
>>> success so in the patch the path is made earlier so PWDREGRESS holds the
>>> path in itself instead of pwd-W
>>> Is that ok?
>>> If someone wants to try it:
>>> you have to run autogen.sh after applying the patch.
>>> /Nicklas
>>I don't think we should make use of $(pwd) in this way, since as
>>implemented by your patch then PWDREGRESS is evaluated to the current
>>path at configure time, rather than at runtime which I suspect will
>>cause some confusion further down the line.
>>The configure.ac part is mostly correct, but I would expect it to look
>>like this, as per the original version:
>>dnl
>>dnl MingW requires use of pwd -W to give proper Windows (not MingW) paths
>>dnl for in-place regression tests
>>dnl
>>case $host_os in
>> *mingw*)
>> PWDREGRESS="pwd -W"
>> PWDREGRESS="pwd"
>>esac
>>AC_DEFINE_UNQUOTED([PWDREGRESS])
>>AC_SUBST([PWDREGRESS])
>>After this, the changes to regress/Makefile.in should then be reasonably
>>simple, e.g.:
>># Where we put our regression installation
>>srcdir=$(shell @PWDREGRESS@)
>>REGRESS_INSTALLDIR=$(srcdir)/00-regress-install
>>HTH,
>>Mark.
>>Mark Cave-Ayland - Senior Technical Architect
>>PostgreSQL - PostGIS
>>Sirius Corporation plc - control through freedom
>>http://www.siriusit.co.uk
>>t: +44 870 608 0063
>>Sirius Labs: http://www.siriusit.co.uk/labs
>>_______________________________________________
>>postgis-devel mailing list
>>postgis-devel at postgis.refractions.net
>>http://postgis.refractions.net/mailman/listinfo/postgis-devel
