[postgis-devel] Cunit and lwerror
Olivier Courtin olivier.courtin at oslandia.com
Sun Jan 24 11:31:01 PST 2010
On Jan 24, 2010, at 5:25 PM, Paul Ramsey wrote:
> You could override the default handlers in your unit tests and provide
> handlers that returned the strings instead of outputting them on
> stderr?
That's a good suggestion !
I tryed something in this way (patch attached), but still meet 2
problems:
1) Common usage with lwerror is to call them directly (i.e without a
return as
     prefix), so i never been able to catch the error message in the
cunit test itself
2) If i suppress the exit instruction in lwerror handler, i introduce
possible
      (huge) side effect...
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20100124/8effae2d/attachment.obj>
Olivier
