[postgis-devel] [PostGIS] #390: ST_AddMeasure to change all the measures on a feature at once
PostGIS trac at osgeo.org
Mon Jan 25 05:05:26 PST 2010
  Reporter:  pramsey      |       Owner:  pramsey
      Type:  enhancement  |      Status:  new
  Priority:  medium       |   Milestone:  PostGIS Future
 Component:  postgis      |     Version:  trunk
Resolution:               |    Keywords:  lrs
Comment (by robe):
 Paul,
 When are you planning on commiting this? After 1.5.0 is released?
 If by chance you had hopes of squeezing it into 1.5.0 which I would hope
 you would, I would rather you expose the SQL interface as well. You can
 only do that if you get it in 1.5.0. That I feel strongly about.  Even if
 its not perfect, I would prefer publicly live code to dormant code that
 only those "in the know" can exercise.
 Yah I know we already called an RC1, but since its short and fairly
 standalone I'm perfectly willing to look the other way and quickly test to
 verify it didn't break anything else if Mark and Kevin are okay with it as
 well.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/390#comment:1>
