[postgis-devel] Proposing 1.5.0
Paul Ramsey pramsey at cleverelephant.ca
Tue Jan 26 13:11:22 PST 2010
I've updated configure.ac to test right down to the patch level now,
so < 3.1.1 will be kciked out at configure time.
P
On Tue, Jan 26, 2010 at 1:00 PM, Kevin Neufeld <kneufeld at refractions.net> wrote:
> I traced this to my installed version of geos.  I accidentally configured
> postgis to use geos 3.1.0.  I know the min requirements are 3.1.1 now, but
> it's curious that configure ran just fine.  Anywho, using 3.1.0, I got the
> one make check failure reported below.
> I retested with 3.2.0 and all tests ran without incident.
> -- Kevin
> On 1/26/2010 12:42 PM, Paul Ramsey wrote:
>> Regression tests also passed cleanly on OpenSolaris.
>> P
>> On Tue, Jan 26, 2010 at 12:26 PM, Paul Ramsey<pramsey at cleverelephant.ca>
>>  wrote:
>>> This test just ran successfully for me under Centos 5.4 in a 32bit VM.
>>> Coming back into your court... :)
>>> P
>>> On Tue, Jan 26, 2010 at 12:06 PM, Paul Ramsey<pramsey at cleverelephant.ca>
>>>  wrote:
>>>> Platform difference or regression? This test works for me on 1.3, 1.4
>>>> and 1.5.
>>>> -- #11 --
>>>> SELECT '#11', ST_Distance (a.g, ST_Intersection(b.g, a.g)) AS distance
>>>> FROM (SELECT
>>>> '01020000000200000050E8303FC2E85141B017CFC05A825541000000E0C0E85141000000205C825541'::geometry
>>>> AS g) a,
>>>>         (SELECT 'LINESTRING(4694792.35840419
>>>> 5638508.89950758,4694793.20840419 5638506.34950758)'::geometry AS g)
>>>> b;
>>>> On Tue, Jan 26, 2010 at 11:53 AM, Kevin Neufeld
>>>>> On Centos 5.2,
>>>>> make check
>>>>>  regress_ogc_prep. ok
>>>>>  regress_bdpoly. ok
>>>>>  regress_proj. ok
>>>>>  dumppoints. ok
>>>>>  wmsservers. ok
>>>>>  tickets. failed (diff expected obtained:
>>>>> /tmp/pgis_reg_5126/test_47_diff)
>>>>> Run tests: 47
>>>>> Failed: 1
>>>>> [buildbot at falcon postgis-1.5.0]$ cat /tmp/pgis_reg_5126/test_47_diff
>>>>> *** tickets_expected    Fri Jan 15 00:13:19 2010
>>>>> --- /tmp/pgis_reg_5126/test_47_out      Tue Jan 26 11:48:01 2010
>>>>> *** 1,5 ****
>>>>>  #2|POLYGON((1 1,1 2,2 2,3 2,3 1,2 1,1 1))
>>>>> ! #11|0
>>>>>  #21|SRID=31293;POINTM(6220.13 5337367.145 4566)
>>>>>  t
>>>>>  ERROR:  AddGeometryColumns() - invalid SRID
>>>>> --- 1,5 ----
>>>>> ! #11|0.889477943128855
>>>>>  t
>>>>> On 1/26/2010 11:40 AM, Paul Ramsey wrote:
>>>>>> I have placed a tarball for testing here:
>>>>>> http://dl.dropbox.com/u/1184727/postgis-1.5.0.tar.gz
>>>>>> I am going to test on Solaris then come back with my vote for
>>>>>> approval.
>>>>>> P
>>>>>> _______________________________________________
>>>>>> postgis-devel mailing list
>>>>>> postgis-devel at postgis.refractions.net
>>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
