[postgis-devel] Implement "make astyle" patch
Nicklas Avén nicklas.aven at jordogskog.no
Thu Jan 28 06:36:34 PST 2010
Ok, I think that works I replaced "astyle" with "tastyle" in both row 6 and 26, then it stoped so I guess it works :-)BTW, how to uninstall astyle for testing it properly. Now I had to cheat.Do I then have to manually delete files, or? /Nicklas
2010-01-28 Mark Cave-Ayland wrote:
Nicklas Avén wrote:
>> well, I have looked a little at this
>> The thing is that when I tried before I installed astyle properly then
>> all my source-files where wiped empty. So my cunit "crash" was caused by
>> empty c-files.
>> When I checked out and tried agin everything worked as expected.
>> But without astyle installed all source files gets empty.
>> I tried it agian by renaming astyle in astyle.sh to something not
>> existing, then the same happened.
>> Can cause a lot of pain if the last thing that happens before
>> committting everything is erased.
>> /Nicklas
>Ah yes, you're probably right. I've just checked a patch into SVN that
>makes the script halt if it can't find astyle - can you try again and
>make sure it works for you?
>ATB,
>Mark.
>Mark Cave-Ayland - Senior Technical Architect
>PostgreSQL - PostGIS
>Sirius Corporation plc - control through freedom
>http://www.siriusit.co.uk
>t: +44 870 608 0063
>Sirius Labs: http://www.siriusit.co.uk/labs
>_______________________________________________
>postgis-devel mailing list
>postgis-devel at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20100128/d4389be9/attachment.html>
