[postgis-devel] [PostGIS] #395: Make check errors on Mac - spheroid area - srid 32702
PostGIS trac at osgeo.org
Thu Jan 28 07:53:44 PST 2010
  Reporter:  colivier  |       Owner:  pramsey
      Type:  defect    |      Status:  new
  Priority:  medium    |   Milestone:  PostGIS 1.5.0
 Component:  postgis   |     Version:  trunk
Resolution:            |    Keywords:  Mac regress  spheroid_area 32702
Comment (by pramsey):
 I just looked more closely at your results, and the numbers being reported
 are just insanely small, it's like either the buffer or the area
 calculation are being carried out in geometry space, not in geography
 space. Can you break down the test case and see what is happening in the
 st_transform() step (are the coordinates being shifted, in fact?) in the
 st_buffer() step (for both geometry and geography) and the st_area() step
 (again for both geometry and geography)?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/395#comment:9>
