[postgis-devel] Implement "make astyle" patch
Nicklas Avén nicklas.aven at jordogskog.no
Thu Jan 28 11:34:35 PST 2010
Mark  It just me not knowing what I'm talking about. I think it is confusing with msys and mingw so I usually keep away from those folders and am just glad it compiles postgis and so on for me. Because of that I actually thought that it was files like .sh I was running inside the system and then just producing dll and exe files for use outside the mingw msys world. That's why I thought it was a differernt approach when I compiled the source code for linux-gnu instead of using the precompiled exe-files for windows. But now I understand a little bit more :-) ThanksNicklas
2010-01-28 Mark Cave-Ayland wrote:
Nicklas Avén wrote:
>> No, everything works fine but I am not using the exe-file, I'm using the
>> linux installation
>What do you mean by Linux installation? Are you testing under a Linux OS
>aswell? Or do you mean an astyle executable which is installed under a
>UNIX-type path?
>ATB,
>Mark.
>Mark Cave-Ayland - Senior Technical Architect
>PostgreSQL - PostGIS
>Sirius Corporation plc - control through freedom
>http://www.siriusit.co.uk
>t: +44 870 608 0063
>Sirius Labs: http://www.siriusit.co.uk/labs
>_______________________________________________
>postgis-devel mailing list
>postgis-devel at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20100128/65ddc515/attachment.html>
