[postgis-devel] [PostGIS] #548: st_numgeometries(geom) returns NULL when geom is not multi
PostGIS trac at osgeo.org
Thu Jul 1 01:20:43 PDT 2010
 Reporter:  giohappy  |       Owner:  pramsey
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 1.5.2
Component:  postgis   |     Version:  1.5.X
 Keywords:            |
 Maybe I'm doing something worng but when I run the following query:
 '''select ST_GeometryN(geom, generate_series(1,ST_NumGeometries(geom))'''
 I receive a single, empty, result when geom is not a multi-geometry.
 I would expect it to returned the same, single, geometry in case it is not
 multi.
 I have a table with both multi and geom. In such case I have to force to
 multi with this:
 '''select ST_GeometryN(''multi''(geom),
 generate_series(1,ST_NumGeometries(''multi''(geom)))'''
 but it is a useless overhead...
 Giovanni
Ticket URL: <http://trac.osgeo.org/postgis/ticket/548>
