[postgis-devel] [PostGIS] #548: st_numgeometries(geom) returns NULL when geom is not multi
PostGIS trac at osgeo.org
Thu Jul 1 01:41:32 PDT 2010
  Reporter:  giohappy  |       Owner:  pramsey
      Type:  defect    |      Status:  closed
  Priority:  medium    |   Milestone:  PostGIS 1.5.2
 Component:  postgis   |     Version:  1.5.X
Resolution:  wontfix   |    Keywords:
Comment(by yabo):
 Such change is going to break a lot of existing code that relies on the
 NULL return for single geometries. The first that comes to mind is
 ST_DumpPoints. I also have production code relying on this behaviour.
 AFAIK there is no other way to test if a geometry is MULTI or not, so
 there should be at least an ST_IsMulti introduced.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/548#comment:5>
