[postgis-devel] [PostGIS] #549: ST_isCollection
PostGIS trac at osgeo.org
Thu Jul 1 02:59:23 PDT 2010
 Reporter:  strk         |       Owner:  pramsey
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.0.0
Component:  postgis      |     Version:  trunk
 Keywords:               |
Comment(by yabo):
 Without the typos :
 +PG_FUNCTION_INFO_V1(LWGEOM_ST_IsCollection);
 +int ST_IsCollection(PG_FUNCTION_ARGS)
 +  PG_LWGEOM* geom;
 +  geom = (PG_LWGEOM *)PG_DETOAST_DATUM(PG_GETARG_DATUM(0));
 +  return lwgeom_is_collection(geom->type);
 I don't have a setup to test this from PostGIS svn right now, so I can't
 tell if it works or not though it compiles fine with this patch.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/549#comment:2>
