[postgis-devel] topology.sql distribution
Paragon Corporation lr at pcorp.us
Wed Jul 7 14:31:54 PDT 2010
+1
That's one reason I never used it, didn't quite understand how to.   Given
that topology is such a hot topic, it would be good to put it up  front for
more critical review.
Thanks,
Regina
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of strk
Sent: Wednesday, July 07, 2010 4:59 PM
To: postgis-devel at postgis.refractions.net
Subject: [postgis-devel] topology.sql distribution
What would you think about giving topology.sql more visibility chances
starting with next release ?
At this time the file is not installed on 'make install', doesn't get the
auto-comment and auto-garden threatment, doesn't provide any upgrade path.
It defines a bunch of pl/pgsql functions and 3 types:
2 meant to be only used as return types from functions and 1 being the
topological equivalent of a GEOMETRY
(ie: the spatial component of a topological feature).
Everything is defined under the 'topology' schema, so it's easy to make rid
of everything when sick of it :P
So, do you think such a deviant file might be accepted in the destdir of a
'make install' ? Maybe renamed to postgis_topology.sql ?
I'm hoping such threatment would expose the code to more eyes and possible
testers and eventually raising some interest in funding or contributing
improvements in it.
--strk;
  ()   Free GIS & Flash consultant/developer
  /\   http://strk.keybit.net/services.html
postgis-devel mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-devel
