[postgis-devel] [PostGIS] #552: [wktraster] ST_SetValue is changing the raster
PostGIS trac at osgeo.org
Wed Jul 28 07:10:06 PDT 2010
 Reporter:  robe       |       Owner:  pracine
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  WKTRaster 0.1.6
Component:  wktraster  |     Version:  1.5.X
 Keywords:             |
Comment(by pracine):
 1) Could you do this to demonstrate that the stored raster was actually
 edited:
 SELECT ST_Value(rast, ST_Point(3427927.75, 5793243.95)) As val FROM
 dummy_rast
 then:
 SELECT ST_Value(ST_SetValue(rast, ST_Point(3427927.75, 5793243.95),50),
 ST_Point(3427927.75, 5793243.95)) As val FROM dummy_rast
 and then:
 dummy_rast
 2) Could you do this:
 SELECT ST_BandPixelType(rast) FROM dummy_rast
 I think you got twice the same result because the pixel value was actually
 not set because 50 is out of the possible value range for this band. Let
 see...
Ticket URL: <http://trac.osgeo.org/postgis/ticket/552#comment:2>
