[postgis-devel] [PostGIS] #553: rt_band_properties test is failing
PostGIS trac at osgeo.org
Fri Jul 30 09:44:34 PDT 2010
 Reporter:  mloskot    |       Owner:  pracine
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:
Component:  wktraster  |     Version:  trunk
 Keywords:             |
 Building WKT Raster (r5759) with PostGIS (r5758) and GEOS (SVN revision
 3087) on Linux 64-bit.
 All PostGIS tests pass, however the rt_band_properties test of WKT Raster
 is failing:
 Running tests
  rt_io. ok
  create_rt_bytea_test. ok
  rt_bytea. ok
  create_rt_box2d_test. ok
  rt_box2d. ok
  create_rt_properties_test. ok
  rt_dimensions. ok
  rt_pixelsize. ok
  rt_upperleft. ok
  rt_rotation. ok
  rt_georeference. ok
  rt_set_properties. ok
  create_rt_band_properties_test. ok
  rt_band_properties. failed (diff expected obtained:
 /tmp/rtpgis_reg_1346/test_14_diff)
  rt_set_band_properties. ok
  rt_pixelvalue. ok
  create_rt_utility_test. ok
  rt_utility. ok
  create_rt_gist_test. ok
  rt_above. ok
  rt_below. ok
  rt_contained. ok
  rt_contain. ok
  rt_left. ok
  rt_overabove. ok
  rt_overbelow. ok
  rt_overlap. ok
  rt_overleft. ok
  rt_overright. ok
  rt_right. ok
  rt_same. ok
  rt_spatial_relationship. ok
  bug_test_car5. ok
 Run tests: 33
 Failed: 1
 make[2]: Leaving directory
 `/home/mloskot/dev/wktraster/_svn/trunk/test/regress'
 make[1]: Leaving directory `/home/mloskot/dev/wktraster/_svn/trunk/test'
 Apparently, something has changed in the NODATA value handling and either
 there is a problem or test case needs to be revised:
 mloskot at vb-ubuntu910-x64:~/dev/wktraster/_svn/trunk$ cat
 *** rt_band_properties_expected 2010-07-30 17:35:08.000000000 +0100
 --- /tmp/rtpgis_reg_1346/test_14_out    2010-07-30 17:41:29.000000000
 +0100
 *** 1,2 ****
 ! WARNING:  Getting NODATA value for a band without NODATA values. Using 0
 --- 1,2 ----
 -530679216
 -530679360
Ticket URL: <http://trac.osgeo.org/postgis/ticket/553>
