[postgis-devel] [PostGIS] #536: Get rid of the STRICT on geography ST_Intersects
PostGIS trac at osgeo.org
Tue Jun 1 04:41:41 PDT 2010
  Reporter:  robe     |       Owner:  pramsey
      Type:  defect   |      Status:  new
  Priority:  high     |   Milestone:  PostGIS 1.5.2
 Component:  postgis  |     Version:  1.5.X
Resolution:           |    Keywords:
Comment (by robe):
 Mark,
 Here is your test
 CREATE TABLE geogtest(gid SERIAL primary key, geog
 geography(POLYGON,4326));
 CREATE INDEX idx_geogtest_geog
   ON geogtest
   USING gist
   (geog);
 INSERT INTO geogtest(geog)
 SELECT ST_Buffer(geog,random()*10) As geog
 FROM (SELECT ST_GeogFromText('POINT(' || i*0.5 || ' ' || j*0.5 || ')') As
 geog
         FROM generate_series(-350,350) As i
                 CROSS JOIN generate_series(-175,175) As j
                 ) As foo
 LIMIT 1000;
 vacuum analyze geogtest;
 SELECT f.gid as gid1, count(f2.gid) As tot
 FROM geogtest As f INNER JOIN geogtest As f2
         ON ST_Intersects(f.geog, f2.geog)
 GROUP BY f.gid;
 With STRICT in there -- this query is unbearably slow. So slow I can't
 wait for it to finish.
 Take strict out and it completes in 78 ms.
 This is running on 8.4, PostGIS 1.5.1
 I think what the STRICT is doing, even though not documented I think that
 its killing the inlining behavior of the SQL function that we've been
 relying on to break out the index piece from rest of the function.  Its a
 non-issue for plpgsql functions since they are treated as blackboxes
 anyway, but a killer for SQL functions where we are counting on the
 planner to see thru it to see there is a piece that can benefit from
 index.
 I suppose we could say this could be a bug in PostgreSQL and maybe worth
 noting.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/536#comment:3>
