[postgis-devel] Two geometries intersects but intersection is empty
Martin Davis mbdavis at refractions.net
Thu Jun 3 11:24:56 PDT 2010
Pierre, can you provide the second geometry in WKBHex?  I can't read the
string that you provided.
Pierre Racine wrote:
> Here is the case:
> SELECT st_intersects(geomA, geomB), astext(st_intersection(geomA, geomB))
> FROM (SELECT
>       st_geomfromtext('POINT(-75.5516150170498 49.2824791927083)',4326) AS geomA,
>       geomfromewkb(E'\\001\\003\\000\\000 \\346\\020\\000\\000\\001\\000\\000\\000\\005\\000\\000\\000\\034\\2373\\316i\\343R\\300q\\217\\016\\232\'\\244H@\\347uFeO\\343R\\300g\\322\\255{5\\244H at l\\324vtH\\343R\\300\\374\\177\\323\\251\\000\\244H@\\241\\375c\\335b\\343R\\300\\007=4\\310\\362\\243H@\\034\\2373\\316i\\343R\\300q\\217\\016\\232\'\\244H@') AS geomB
> ) foo
> Sorry I can't provide it as wkt as the wkt version return the expected result (and the wkb version does not (before I read Paul's last FAQ)).
> Pierre
>> -----Original Message-----
>> From: postgis-devel-bounces at postgis.refractions.net [mailto:postgis-devel-
>> bounces at postgis.refractions.net] On Behalf Of Martin Davis
>> Sent: 3 juin 2010 12:15
>> To: PostGIS Development Discussion
>> Subject: Re: [postgis-devel] Two geometries intersects but intersection is empty
>> Can you post the case?
>> This can happen because the intersects predicate test is more accurate
>> than the intersection computation.  (Technically speaking, it's possible
>> to detect that two segments intersect, but be unable to compute an
>> accurate point that represents the intersection).
>>> Hi,
>>> Is it possible that st_intersects returns true on two geometries but their st_intersection returns
>> "GEOMETRYCOLLECTION EMPTY"?
>>> I have a nice case here...
>>> Pierre
>>> postgis-devel mailing list
>>> postgis-devel at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
>> Martin Davis
>> Senior Technical Architect
>> Refractions Research, Inc.
>> (250) 383-3022
Martin Davis
(250) 383-3022
