[postgis-devel] [PostGIS] #538: Problem with rendering PostgreSQL 9.0 beta ST_AsBinary
PostGIS trac at osgeo.org
Fri Jun 4 00:17:38 PDT 2010
 Reporter:  robe                   |       Owner:  pramsey
     Type:  defect                 |      Status:  new
 Priority:  medium                 |   Milestone:  PostGIS 1.5.2
Component:  postgis                |     Version:  1.5.X
 Keywords:  postgresql9.0 windows  |
 I'm not sure if this is my install or something wrong with OpenJump or the
 ST_AsBinary output emitted by PostgreSQL 9.0.  I just tried displaying my
 PostgreSQL 9.0 beta 1 PostGIS 1.5.2SVN install on Windows in OpenJump, and
 I can't.
 It gives the error (Unknown WKB type 48(Parse Exception) when I run this
 query
 SELECT ST_AsBinary(geom)
 FROM
 bay_area_cities
 It fails for any geometry table in my PostgreSQL 9.0.  However I can
 render the geometries fine in QuantumGIS.
 I can also render my PostgreSQL 8.4 PostGIS 1.5 geometries fine as well in
 OpenJump.
 I'm not sure if this is just a windows thing or something strange that the
 PostgreSQL 9.0 is tacking on to the ST_AsBinary output that is tripping up
 OpenJump.
 Can someone running a Linux PostgreSQL 9.0 beta 1 install test it out.
 As far as I can tell, the geometries are fine.  I can union them, run
 areas etc. So seems like it might be isolated to the output.
 Details of my install (that I built around 2010-05-11) -- the one on
 Windows Experimental page.
 "POSTGIS="1.5.2SVN" GEOS="3.2.2-CAPI-1.6.2" PROJ="Rel. 4.6.1, 21 August
 2008" LIBXML="2.7.6" USE_STATS"
Ticket URL: <http://trac.osgeo.org/postgis/ticket/538>
