[postgis-devel] [PostGIS] #541: unique constraint on geography not enforced on update
trac at osgeo.org
Thu Jun 10 02:22:17 PDT 2010
Reporter: arno | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 1.5.2
Component: postgis | Version: 1.5.X
Keywords: |
when creating a column of type geography, and declaring it as unique, I
can't insert two rows with similar geography (that's normal). But I can
insert a point with a different geography, and update it afterwards. I'll
insert a sql example to be more clear.
The bug does not appear when using geometry instead of geography.
Ticket URL: <http://newtrac.osgeo.org/postgis/ticket/541>
