[postgis-devel] reassign owned to doesn't work with postgis operator class and class families
Nicklas Avén
nicklas.aven at jordogskog.no
Mon Jun 14 02:07:38 PDT 2010
Hallo
I guess this is a postgresql issue, but wanted to check here first.
The function REASSIGN OWNED
http://www.postgresql.org/docs/8.4/interactive/sql-reassign-owned.html
returns error when PostGIS is installed. I found that it is the operator classes and operator familys giving the error.
the operator classes gives:
ERROR: unexpected classid 2616
and the operator families gives:
ERROR: unexpected classid 2753
There is no problem to change the owner by altering the objects, so if I want to assign all objects to user postgres and first run:
ALTER OPERATOR CLASS btree_geography_ops USING btree OWNER TO postgres;
ALTER OPERATOR CLASS btree_geometry_ops USING btree OWNER TO postgres;
ALTER OPERATOR CLASS gist_geography_ops USING gist OWNER TO postgres;
ALTER OPERATOR CLASS gist_geometry_ops USING gist OWNER TO postgres;
ALTER OPERATOR FAMILY btree_geography_ops USING btree OWNER TO postgres;
ALTER OPERATOR FAMILY btree_geometry_ops USING btree OWNER TO postgres;
ALTER OPERATOR FAMILY gist_geography_ops USING gist OWNER TO postgres;
ALTER OPERATOR FAMILY gist_geometry_ops USING gist OWNER TO postgres;
then I can run :
REASSIGN OWNED BY nicklas TO postgres;
without any errors.
I have only tried this with
postgresql 8.4.4
with PostGIS 1.5.1
Is it a postgresql problem solely? What makes me wonder is that I tried a few searches with google and didn't get anything about it at a first sight. If it is postgresql I expect to find it mentioned all over internet, but I on't understand how it could be a postgis problem either.
I will also put a ticket about that we are not droping the operator families with postgis_uninstall.sql
Thanks
Nicklas
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20100614/6d6ca5fd/attachment.html>
