[postgis-devel] [PostGIS] #545: error retrieving single point linestring WKB
PostGIS trac at osgeo.org
Tue Jun 22 14:52:45 PDT 2010
 Reporter:  ravenAtSafe  |       Owner:  pramsey
     Type:  defect       |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 1.5.2
Component:  postgis      |     Version:  1.5.X
 Keywords:               |
 If you insert a single point linestring into PostGIS (via WKB, as WKT of
 the same geo is rejected), it can't be read back.
 insert into single_point_linestring (geom) values
 (ST_GeomFromWKB(decode('01020000000100000000000000000008400000000000000840','hex')))
 select ST_AsText(geom) from single_point_linestring
 ERROR:  geometry requires more points
 ********** Error **********
 SQL state: XX000
Ticket URL: <http://trac.osgeo.org/postgis/ticket/545>
