[postgis-devel] [PostGIS] #547: ST_contains memory problem when used between polygon and mixed geometry
PostGIS trac at osgeo.org
Mon Jun 28 09:59:49 PDT 2010
 Reporter:  twain               |       Owner:  pramsey
     Type:  defect              |      Status:  new
 Priority:  high                |   Milestone:  PostGIS 1.5.2
Component:  postgis             |     Version:  1.5.X
 Keywords:  ST_contains memory  |
Comment(by pramsey):
 I think I see where this could come from, as the prepared geometry cache
 system expects a query to be *either* a p-i-p situation or a p-and-g
 situation, but not both at the same time. One fix could be just ripping
 out the postgis-native implementation (for the p-i-p case) of the caching
 system.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/547#comment:1>
