[postgis-devel] st_isvalid linestring and multilinestring
Martin Davis mbdavis at refractions.net
Tue Mar 2 14:47:54 PST 2010
Thanks for catching this, strk.  I'll add the unit test you provided,
and have a look at cleaning up this variable.
strk wrote:
> I've found the bug in GEOS, but also unused code in JTS
> which probably confused the porting process.
> In IsValidOp.java you're using an 'isChecked' private
> boolean which you then never use.
> I guess it used to be used before like it is in GEOS,
> only it prevents (in GEOS) checking validity of any
> component past the first of any MULTI* !!!
> Haven't checked in previous versions but the fact
> neither JTS nor GEOS contained *any* testcase for
> invalid geoms being after first one is pretty scary.
> --strk;
>   Share. It's fair.
>   http://iwouldntsteal.net
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
