[postgis-devel] PostGISonline.org is online :-)
Nicklas Avén nicklas.aven at jordogskog.no
Mon Mar 8 06:23:09 PST 2010
Hallo Jeff
It should be up and running. From here it seems to work.
Strange if you can't reach it.
About the VPS, my understanding is that it is the case as you say. In Linode you have to activate an internal IP-address if you want to communicate inside the datacenter. Since I haven't done that I guess my VPS is harmless for the rest of the virtual servers.
I am very impressed so far by linode.com. It was very easy to make an image copy of the whole server, so I have one copy saved.
I'm not worried about the site in itself, as you say I can just boot the copy instead. What I don't want is an attacker using the server for spamming or sending out virus. Then I think the site will soon be closed down.
About updateing on commit I have thought about it and I think that's a good idea.
There is two alternatives. Just a dropdown choosing database between latest stable PostGIS installation and nightly build or a special folder for development snapshot site. I think the latter is better to keep the frontside as simple as possible since it is the people not knowing so much about PostGIS and spatial querieng that I think is the main target.
But I absolutely think it would be cool if anyone could test tnew functionality right after commit even if they are not compiling themselves.
How to make a script running once a day. I guess the script in i self must be quite simple when the only thing to do is
update svn
configure make make install
restart server
Can you still not reach the site?
Thanks
Nicklas
2010-03-08 Jeff Adams  wrote:
One last-resort style of security would be:
>- Make sure your router disallows communication from your virtual server to anything else on your internal network.
>- Take a snapshot of the virtual server, and restore to the snapshot every day (or every hour).
>That way if/when it gets pwned, it's only pwned for a day (or an hour).
>It also has the effect of resetting the database to a known state (I'm not sure if the site lets you write data to the DB or not).
>That's inconvenient of course if you're trying to do frequent updates to PostGIS (like from every checkin or something).
>I can't connect to the site right now, I dunno if you have taken it down, or you got slashdotted by this mailing list, or what.
>Jeff
On Sun, Mar 7, 2010 at 8:45 PM, Nicklas Avén <nicklas.aven at jordogskog.no> wrote:
Hallo >
My first attempt with postgisonline. www.postgisonline.org>
It is now up and running, but totally without any cosmetics. >
For those don't knowing what I'm talking about from some mails in 2009 it is an idea about a site to try and test PostGIS.>
It is also possible to write simple tutorials that control text, sql-code, background-map and a backgroundimage if wanted.>
The tutorial thing works and makes it possible to just pass the tutorial-utl as a querystring, but I have disabled it now because I don't know how to handle the security issues.>
The site is ran on linode.com as a Xen-virtulized ubuntu-server. >
Now there are only a few tables to use in the database but I will put in more.>
Now geometry-collections is not handled, but I think I have an idea how to solve that. But it will not be right now.>
Try it and give feedback.>
I will wait a few days before mailing on the user-list because I want to find the most obvious bugs first.>
I someone wants to help I'm greatful.>
I will put all code in public when I have cleaned and structured it a little better.>
I see a lot of development potential init and would like to make it some sort of open project. >
I have tried it in IE and Firefox>
So, navigate to www.postgisonline.org and try it>
Thanks>
Nicklas
>_______________________________________________
>postgis-devel mailing list
>postgis-devel at postgis.refractions.net
>postgis.refractions.net/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20100308/c91b1198/attachment.html>
