[postgis-devel] PostGISonline.org is online :-)
Jeff Adams jadams at azavea.com
Mon Mar 8 07:22:35 PST 2010
My packets die after ...telecity.net (tried multiple times):
Tracing route to www.postgisonline.org [109.74.203.88]
over a maximum of 30 hops:
  1     1 ms     1 ms    <1 ms  216.158.51.81
  2     8 ms    24 ms     9 ms  core-1-mul1.sdfc.dca.net [216.158.59.49]
  3   147 ms   203 ms   175 ms  core-5-gig-vlan-500.sdfc.dca.net[216.158.2.3]
  4     4 ms     7 ms     3 ms  ge2-4.br01.phl02.pccwbtn.net [63.218.31.9]
  5    79 ms    86 ms    79 ms
telecity.ge9-9.br02.ldn01.pccwbtn.net[63.218.13.222]
  6    80 ms    81 ms    80 ms
te4-1-dist65-01.lon10.telecity.net[217.20.44.218]
  7     *        *        *     Request timed out.
  8     *        *        *     Request timed out.
  9     *        *        *     Request timed out.
 (etc).
How weird.
On Mon, Mar 8, 2010 at 10:05 AM, Pierre Racine
<Pierre.Racine at sbf.ulaval.ca>wrote:
>  I can reach it from North America, no problem (10h00 GMT -05h00).
> Pierre
> *From:* postgis-devel-bounces at postgis.refractions.net [mailto:
> postgis-devel-bounces at postgis.refractions.net] *On Behalf Of *Nicklas Avén
> *Sent:* 8 mars 2010 09:57
> *To:* PostGIS Development Discussion
> *Subject:* Re: [postgis-devel] PostGISonline.org is online :-)
> very strange
> What can be the reason that I can reach it and not you?
> I can reach it both from my phone via gprs and through my usual internet
> connection.
> Yes, it is the right ip-address
> /Nicklas
> 2010-03-08 Jeff Adams wrote:
> I still can't reach it:
> >$ ping www.postgisonline.org
> >Pinging www.postgisonline.org [109.74.203.88] with 32 bytes of data:
> >Request timed out.
> >(I also get a timeout when trying to access it in a browser)
> >Is that the right IP address?
> >To run the script once a day, you could use something simple like cron.
> There are continuous integration services you could install that are smart
> enough to check SVN (the one I'm familiar with is CruiseControl, but there
> are others) and build when necessary.  It also would not be too hard to have
> your script just look at the last checkin time in SVN and only run if
> there's been a change in the last day, hour, 5 minutes, however often you
> decide to check.
> >Jeff
> On Mon, Mar 8, 2010 at 9:23 AM, Nicklas Avén <nicklas.aven at jordogskog.no>
> wrote:
> Hallo Jeff
> > It should be up and running. From here it seems to work.
> > Strange if you can't reach it.
> > About the VPS, my understanding is that it is the case as you say. In
> Linode you have to activate an internal IP-address if you want to
> communicate inside the datacenter. Since I haven't done that I guess my VPS
> is harmless for the rest of the virtual servers.
> > I am very impressed so far by linode.com. It was very easy to make an
> image copy of the whole server, so I have one copy saved.
> > I'm not worried about the site in itself, as you say I can just boot the
> copy instead. What I don't want is an attacker using the server for spamming
> or sending out virus. Then I think the site will soon be closed down.
> > About updateing on commit I have thought about it and I think that's a
> good idea.
> > There is two alternatives. Just a dropdown choosing database between
> latest stable PostGIS installation and nightly build or a special folder for
> development snapshot site. I think the latter is better to keep the
> frontside as simple as possible since it is the people not knowing so much
> about PostGIS and spatial querieng that I think is the main target.
> > But I absolutely think it would be cool if anyone could test tnew
> functionality right after commit even if they are not compiling themselves.
> > How to make a script running once a day. I guess the script in i self
> must be quite simple when the only thing to do is
> > update svn
> > configure make make install
> > restart server
> > Can you still not reach the site?
> > Thanks
> > Nicklas>
> > One last-resort style of security would be:
> > >- Make sure your router disallows communication from your virtual server
> to anything else on your internal network.
> > >- Take a snapshot of the virtual server, and restore to the snapshot
> every day (or every hour).
> > >That way if/when it gets pwned, it's only pwned for a day (or an hour).
> > >It also has the effect of resetting the database to a known state (I'm
> not sure if the site lets you write data to the DB or not).
> > >That's inconvenient of course if you're trying to do frequent updates to
> PostGIS (like from every checkin or something).
> > >I can't connect to the site right now, I dunno if you have taken it
> down, or you got slashdotted by this mailing list, or what.
> > >Jeff
> On Sun, Mar 7, 2010 at 8:45 PM, Nicklas Avén <nicklas.aven at jordogskog.no>
> wrote:
> Hallo
> My first attempt with postgisonline. www.postgisonline.org
> It is now up and running, but totally without any cosmetics.
> For those don't knowing what I'm talking about from some mails in 2009 it
> is an idea about a site to try and test PostGIS.
> It is also possible to write simple tutorials that control text, sql-code,
> background-map and a backgroundimage if wanted.
> The tutorial thing works and makes it possible to just pass the
> tutorial-utl as a querystring, but I have disabled it now because I don't
> know how to handle the security issues.
> The site is ran on linode.com as a Xen-virtulized ubuntu-server.
> Now there are only a few tables to use in the database but I will put in
> more.
> Now geometry-collections is not handled, but I think I have an idea how to
> solve that. But it will not be right now.
> Try it and give feedback.
> I will wait a few days before mailing on the user-list because I want to
> find the most obvious bugs first.
> I someone wants to help I'm greatful.
> I will put all code in public when I have cleaned and structured it a
> little better.
> I see a lot of development potential init and would like to make it some
> sort of open project.
> I have tried it in IE and Firefox
> So, navigate to www.postgisonline.org and try it
> Thanks
> Nicklas
> > >_______________________________________________
> > > postgis-devel mailing list
> > >postgis-devel at postgis.refractions.net
> >postgis.refractions.net/mailman/listinfo/postgis-devel
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20100308/b9731cc1/attachment.html>
