[postgis-devel] PostGISonline.org is online :-)
Nicklas Avén nicklas.aven at jordogskog.no
Mon Mar 8 13:20:57 PST 2010
There seems to be some problem when using both iframes and AJAX in firefox. Sometimes, not always the AJAX request never get sent from the browser.
That's why the site has been acting strangely this evening when I have tried to figure out what is happening.
But now it is restored because I have to do a bigger rewriting I think so I shall set everything up locally.
Does anyone happen to knoe anything about this problem here?
/Nicklas
2010-03-08 Nicklas Avén  wrote:
can it be a matter of time?
>it was about 15 hours ago that I moved the domain name from one webhost to this site.  Somewhere it said that it might take up to 48 hours before it shows up?
>But that shouldn't be the problem when you get the right ip-address associated I guess?
>strange!
>/Nicklas
>2010-03-08 Jeff Adams  wrote:
>My packets die after ...telecity.net (tried multiple times):
>>Tracing route to www.postgisonline.org [109.74.203.88]
>>over a maximum of 30 hops:
>>  1     1 ms     1 ms    <1 ms  216.158.51.81
>>  2     8 ms    24 ms     9 ms  core-1-mul1.sdfc.dca.net [216.158.59.49]
>>  3   147 ms   203 ms   175 ms  core-5-gig-vlan-500.sdfc.dca.net [216.158.2.3]
>>  4     4 ms     7 ms     3 ms  ge2-4.br01.phl02.pccwbtn.net [63.218.31.9]
>>  5    79 ms    86 ms    79 ms  telecity.ge9-9.br02.ldn01.pccwbtn.net [63.218.13.222]
>>  6    80 ms    81 ms    80 ms  te4-1-dist65-01.lon10.telecity.net [217.20.44.218]
>>  7     *        *        *     Request timed out.
>>  8     *        *        *     Request timed out.
>>  9     *        *        *     Request timed out.
>> (etc).
>>How weird.
On Mon, Mar 8, 2010 at 10:05 AM, Pierre Racine <Pierre.Racine at sbf.ulaval.ca> wrote:
I can reach it from North America, no problem (10h00 GMT -05h00).
Pierre
From: postgis-devel-bounces at postgis.refractions.net[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of NicklasAvén
>>Sent: 8 mars 2010 09:57
>>To: PostGIS Development Discussion
>>Subject: Re: [postgis-devel] PostGISonline.org is online :-)>>
very strange
>>What can be the reason that I can reach it and not you?
>>I can reach it both from my phone via gprs and through my usual internetconnection.
>>Yes, it is the right ip-address
>>/Nicklas
>>I still can't reach it:
>>>$ ping www.postgisonline.org
>>>Pinging www.postgisonline.org[109.74.203.88] with 32 bytes of data:
>>>Request timed out.
>>>(I also get a timeout when trying to access it in a browser)
>>>Is that the right IP address?
>>>To run the script once a day, you could use something simple likecron.  There are continuous integration services you could install thatare smart enough to check SVN (the one I'm familiar with is CruiseControl, butthere are others) and build when necessary.  It also would not be too hardto have your script just look at the last checkin time in SVN and only run ifthere's been a change in the last day, hour, 5 minutes, however often youdecide to check.
>>>Jeff
On Mon, Mar 8, 2010 at 9:23 AM, Nicklas Avén<nicklas.aven at jordogskog.no> wrote:
Hallo Jeff
>>> It should be up and running. From here it seems to work.
>>> Strange if you can't reach it.
>>> About the VPS, my understanding is that it is the case as you say. InLinode you have to activate an internal IP-address if you want to communicateinside the datacenter. Since I haven't done that I guess my VPS is harmless forthe rest of the virtual servers.
>>> I am very impressed so far by linode.com.It was very easy to make an image copy of the whole server, so I have one copysaved.
>>> I'm not worried about the site in itself, as you say I can just boot thecopy instead. What I don't want is an attacker using the server for spamming orsending out virus. Then I think the site will soon be closed down.
>>> About updateing on commit I have thought about it and I think that's agood idea.
>>> There is two alternatives. Just a dropdown choosing database betweenlatest stable PostGIS installation and nightly build or a special folder fordevelopment snapshot site. I think the latter is better to keep the frontsideas simple as possible since it is the people not knowing so much about PostGISand spatial querieng that I think is the main target.
>>> But I absolutely think it would be cool if anyone could test tnewfunctionality right after commit even if they are not compiling themselves.
>>> How to make a script running once a day. I guess the script in i self mustbe quite simple when the only thing to do is
>>> update svn
>>> configure make make install
>>> restart server
>>> Can you still not reach the site?
>>> Thanks
>>> Nicklas> >>
>>> One last-resort style of security would be:
>>> >- Make sure your router disallows communication from your virtualserver to anything else on your internal network.
>>> >- Take a snapshot of the virtual server, and restore to the snapshotevery day (or every hour).
>>> >That way if/when it gets pwned, it's only pwned for a day (or anhour).
>>> >It also has the effect of resetting the database to a known state (I'mnot sure if the site lets you write data to the DB or not).
>>> >That's inconvenient of course if you're trying to do frequent updatesto PostGIS (like from every checkin or something).
>>> >I can't connect to the site right now, I dunno if you have taken itdown, or you got slashdotted by this mailing list, or what.
>>> >Jeff
On Sun, Mar 7, 2010 at 8:45 PM, Nicklas Avén<nicklas.aven at jordogskog.no> wrote:
Hallo
My first attempt with postgisonline. www.postgisonline.org
It is now up and running, but totally without any cosmetics.
For those don't knowing what I'm talking about fromsome mails in 2009 it is an idea about a site to try and test PostGIS.
It is also possible to write simple tutorials that controltext, sql-code, background-map and a backgroundimage if wanted.
The tutorial thing works and makes it possible to just passthe tutorial-utl as a querystring, but I have disabled it now because I don'tknow how to handle the security issues.
The site is ran on linode.com as a Xen-virtulized ubuntu-server.
Now there are only a few tables to use in the database but Iwill put in more.
Now geometry-collections is not handled, but I think I havean idea how to solve that. But it will not be right now.
Try it and give feedback.
I will wait a few days before mailing on the user-listbecause I want to find the most obvious bugs first.
I someone wants to help I'm greatful.
I will put all code in public when I have cleaned andstructured it a little better.
I see a lot of development potential init and would like tomake it some sort of open project.
I have tried it in IE and Firefox
So, navigate to www.postgisonline.org and try it
Thanks
Nicklas
>>> >_______________________________________________
>>> > postgis-devel mailing list
>>> >postgis-devel at postgis.refractions.net
>postgis.refractions.net/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20100308/23a56b06/attachment.html>
