[postgis-devel] Upcoming releases: 1.5.1
Paragon Corporation lr at pcorp.us
Mon Mar 8 13:53:38 PST 2010
> I have enough time to drop a tarball, but not enough to do any ticket
> closing. 1.5.1: better than nothing? Here's the list of tickets closed
> against the 1.5.1 milestone
http://trac.osgeo.org/postgis/query?status=closed&milestone=PostGIS+1.5.1&or
der=priority
> Probably there are some other issues that have been closed, but
> against the 2.0 milestone.
Paul,
Any chance we can get this bug fixed before we release.
http://trac.osgeo.org/postgis/ticket/410
 It affects both 1.4 and 1.5 branches (and also 1.3/1.2 etc but I can live
without 1.3 being patched I suppose).
I had mistakenly thought it was only a 1.4 issue.  Below is a test to prove
CREATE TABLE foo ()WITH (OIDS = TRUE);
SELECT AddGeometryColumn( 'foo', 'the_geom', -1, 'LINESTRING', 2);
SELECT AddGeometryColumn( 'foo', 'the_geom2', -1, 'LINESTRING', 2);
INSERT INTO foo(the_geom, the_geom2) VALUES (ST_GeomFromText('LINESTRING(0
0, 1 3)'), ST_GeomFromText('LINESTRING(0 0, 1 3)'));
UPDATE foo SET the_geom=ST_SetPoint(the_geom, 0, 'POINT(100000 200000)');
SELECT st_astext(the_geom), st_astext(the_geom2) FROM foo;
SELECT st_astext(ST_Envelope(the_geom)), st_astext(ST_Envelope(the_geom2))
FROM foo;
SELECT ST_Box2D(the_geom),  ST_Box2D(ST_ASText(the_geom))
FROM foo;
---- This returns an erroneous cached box on my 1.5 install which screws up
spatial query results.
BOX(0 0,1 3);BOX(1 3,100000 200000)
I consider it somewhat critical, since I still have hack code to compensate
for this defect that would be nice to get rid of and since we changed the
name of DropBbox etc. my hack code has to be different for each version of
PostGIS now.
Also I do believe Devrim asked about both 1.5.1 and 1.4.2
Thanks,
Regina
