[postgis-devel] ST_GeometrySplit
Chris Hodgson chodgson at refractions.net
Wed Mar 10 10:26:34 PST 2010
Hmm... nevermind, I guess it's not.
select st_astext(st_difference( st_geomfromtext('LINESTRING(0 0, 0 2)'),
st_geomfromtext('POINT(0 1)')));
      st_astext
 LINESTRING(0 0,0 2)
Chris
Chris Hodgson wrote:
> Isn't this the same as st_difference(A,B), when given any of those
> pairs of arguments? Wrap it in an st_dump() if you want to separate
> the individual results?
> Chris
> strk wrote:
>> Brain picking you guys about a ST_GeometrySplit.
>> The cases of interest seem to be:
>>  - Split polygon by line
>>  - Split line by line
>>  - Split line by point
>> Initial questions:
>>  - Should we allow multi-segment "blade" lines ?
>>    (where a single polygon or line might be cut in multiple pieces)
>>  - Should we allow multi-component inputs ?
>>    (where the "blade" might cut a single component)
>> Both questions are related to the kind of returned output,
>> that is: should output be always composed by 2 parts or
>> possibly multiple parts ?
>> Comments welcome.
>> --strk;
>>   ()   Free GIS & Flash consultant/developer
>>   /\   http://strk.keybit.net/services.html
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
