[postgis-devel] ST_GeometrySplit
Chris Hodgson
chodgson at refractions.net
Wed Mar 10 11:04:59 PST 2010
ST_Difference, according to IBM:
http://publib.boulder.ibm.com/infocenter/db2luw/v9/topic/com.ibm.db2.udb.spatial.doc/rsbp4035.html
"Both [input] geometries must be of the same dimension."
However, I don't see any use to the results of the existing
implementation for non-equal dimension geometries... if it is possible,
it might be nice to just make ST_difference "work" for these cases
rather than introduce another function with virtually identical results.
Though I suppose the intention of "splitting" is different enough from
"subtracting" to perhaps warrant a separate function. Also I don't know
if the behavior of st_difference in the case of non-equal dimension
inputs is specified in SQL_MM or otherwise.
Chris
Chris Hodgson wrote:
> Works for the line case though:
> select st_astext(st_difference( st_geomfromtext('LINESTRING(0 0, 0
> 2)'), st_geomfromtext('LINESTRING(-1 1, 1 1)')));
> st_astext
> MULTILINESTRING((0 0,0 1),(0 1,0 2))
> Perhaps the point case is a precision issue? Or I don't know the exact
> spec for this function.
> Not the result I expect for the polygon-line case either:
> select st_astext(st_difference( st_geomfromtext('POLYGON((0 0, 0 2, 2
> 0, 0 0))'), st_geomfromtext('LINESTRING(-1 1, 2 1)')));
> st_astext ------------------------------------
> POLYGON((0 0,0 1,0 2,1 1,2 0,0 0))
> I'm running on old stuff here, maybe someone can check on a newer
> version...
> select postgis_full_version();
> POSTGIS="1.3.3" GEOS="3.0.0-CAPI-1.4.1" PROJ="Rel. 4.6.1, 21 August
> 2008" USE_STATS
> Chris
>> Hmm... nevermind, I guess it's not.
>> 2)'), st_geomfromtext('POINT(0 1)')));
>> LINESTRING(0 0,0 2)
>> Chris
>>> Isn't this the same as st_difference(A,B), when given any of those
>>> pairs of arguments? Wrap it in an st_dump() if you want to separate
>>> the individual results?
>>> Chris
>>> strk wrote:
>>>> Brain picking you guys about a ST_GeometrySplit.
>>>> The cases of interest seem to be:
>>>> - Split polygon by line
>>>> - Split line by line
>>>> - Split line by point
>>>> Initial questions:
>>>> - Should we allow multi-segment "blade" lines ?
>>>> (where a single polygon or line might be cut in multiple pieces)
>>>> - Should we allow multi-component inputs ?
>>>> (where the "blade" might cut a single component)
>>>> Both questions are related to the kind of returned output,
>>>> that is: should output be always composed by 2 parts or
>>>> possibly multiple parts ?
>>>> Comments welcome.
>>>> --strk;
>>>> () Free GIS & Flash consultant/developer
>>>> /\ http://strk.keybit.net/services.html
>>>> _______________________________________________
>>>> postgis-devel mailing list
>>>> postgis-devel at postgis.refractions.net
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
