[postgis-devel] ST_GeometrySplit
strk strk at keybit.net
Thu Mar 11 13:12:47 PST 2010
On Wed, Mar 10, 2010 at 11:49:18AM -0800, Chris Hodgson wrote:
> Right-side vs left side can be ambiguous too... an example is a circle
> or spiral that is split by a line on only one side.
Argh, you're right. Here's a simple example:
    |  ?|R  |
       L|?  |
  IN -------+
       CUT
I marked with 'L' the part which is on the Left and with R
the part which is on the Right of the cut line.
The question mark is for the part which is both
on the Right (lower intersection point)
*and* on the Left (higher intersection point).
Maybe Martin has some neat topological rabit in his hat ?
--strk;
  ()   Free GIS & Flash consultant/developer
  /\   http://strk.keybit.net/services.html
