[postgis-devel] dumppoints.sql regression test relies on special configuration
strk strk at keybit.net
Fri Mar 12 05:54:42 PST 2010
Errors on make check:
! ERROR:  stack depth limit exceeded
! HINT:  Increase the configuration parameter "max_stack_depth", after ensuring the platform's stack
depth limit is adequate.
This is running the dumppoints.sql
--strk;
  ()   Free GIS & Flash consultant/developer
  /\   http://strk.keybit.net/services.html
