[postgis-devel] [wktraster] Debugging with WKT Raster
Mateusz Loskot Mateusz.Loskot at cadcorp.com
Fri Mar 12 09:18:42 PST 2010
Jorge Arevalo wrote:
> I work in a GNU/Linux enviroment. WKT Raster is compiled passing
> options -g -O2 to the compiler (gcc, in my case). With these options,
> is difficult to use gdb without fighting with assembler code.
> I know, RT_API_DEBUG variable should be enough in most cases, to show
> debug messages. But may I suggest to disable -O2 option when a kind of
> debug variable is defined? I don't know if it's a good idea. And I
> don't know how this changes would affect the windows builds...
Personally, I'm fine with any changes you want/need to apply here.
Best regards,
Mateusz Loskot
Senior Programmer, Cadcorp
http://www.cadcorp.com
This email is confidential and may be privileged and should not be used, read
or copied by anyone who is not the  original intended recipient. If you have
received this email in error  please inform the sender and delete it from
your mailbox or any other storage mechanism. Unless specifically stated,
nothing in this email constitutes an offer by Cadcorp and Cadcorp does not
warrant that any information contained in this email is accurate.
Cadcorp cannot accept liability for any statements made which are clearly the
sender's own and not expressly made on behalf of Cadcorp or one of its agents.
Please rely on your own virus check. No responsibility is taken by Cadcorp
for any damage arising out of any bug or virus infection.
