[postgis-devel] [PostGIS] #400: ST_Split
PostGIS trac at osgeo.org
Tue Mar 16 13:56:40 PDT 2010
#400: ST_Split
  Reporter:  strk     |       Owner:  strk
      Type:  defect   |      Status:  assigned
  Priority:  medium   |   Milestone:  PostGIS 2.0.0
 Component:  postgis  |     Version:
Resolution:           |    Keywords:
Changes (by strk):
  * summary:  ST_SplitGeometry => ST_Split
Comment:
 Contract changed. We always return a collection but of as many elements as
 required to represent all components of output.
 Currently line-by-point, line-by-line and poly-by-line splitting are
 supported and
 the function name is ST_Split.
 Unsupported are all MULTI* and GEOMETRYCOLLECTION, but I'd like to add
 support for them
 too. The use case I have in mind is in conjunction to the ST_WrapX
 function proposed
 in ticket #454 (still not convinced about that function name:)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/400#comment:5>
