[postgis-devel] [PostGIS] #466: test_rect_tree_contains_point segfaults
PostGIS trac at osgeo.org
Tue Mar 16 14:22:36 PDT 2010
 Reporter:  strk     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 1.5.2
Component:  postgis  |     Version:  1.5.X
 Keywords:           |
 Running test 'test_rect_tree_contains_point' in suite 'PostGIS Measures
 Suite'.
 Program received signal SIGSEGV, Segmentation fault.
 0x000000000040a217 in test_rect_tree_contains_point () at
 cu_measures.c:130
 130             tree = rect_tree_new(poly->rings[0]);
 (gdb) bt
 #0  0x000000000040a217 in test_rect_tree_contains_point () at
 cu_measures.c:130
 #1  0x00007f0a5821945a in ?? () from /usr/lib/libcunit.so.1
 #2  0x00007f0a58219877 in CU_run_test () from /usr/lib/libcunit.so.1
 #3  0x000000000040e2e4 in main (argc=2, argv=<value optimized out>)
     at cu_tester.c:118
 At revision 5443.
 Did ./autogen.sh; ./configure && make clean && make && make check
Ticket URL: <http://trac.osgeo.org/postgis/ticket/466>
