[postgis-devel] [PostGIS] #466: test_rect_tree_contains_point segfaults
PostGIS trac at osgeo.org
Wed Mar 17 00:34:12 PDT 2010
  Reporter:  strk     |       Owner:  pramsey
      Type:  defect   |      Status:  closed
  Priority:  medium   |   Milestone:  PostGIS 1.5.2
 Component:  postgis  |     Version:  1.5.X
Resolution:  fixed    |    Keywords:
Changes (by strk):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Alright, as of r5445 'make clean' does what it's supposed to do, and next
 build&check
 after make clean now succeeds with no failures nor segfaults.
 I'm afraid dependencies are still a big mess, but at least you can clean
 now.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/466#comment:7>
