[postgis-devel] [PostGIS] #469: st_union() in some queries produces segfaults and/or ERROR: array size exceeds the maximum allowed (134217727)
PostGIS trac at osgeo.org
Mon Mar 22 16:26:24 PDT 2010
 Reporter:  mgleahy  |       Owner:  pramsey
     Type:  patch    |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 1.5.2
Component:  postgis  |     Version:  1.5.X
 Keywords:           |
 As indicated in the subject, in some circumstances the st_union() function
 would result in either a segfault or a trapped error that would be
 reported as
 Investigation that concluded on the users mailing list
 (http://postgis.refractions.net/pipermail/postgis-users/2010-
 March/026245.html) indicates that this is due to "some memory management
 changes which required changes to array_agg() and which had some risk of
 causing problems for other sites with similar coding"
 The patch attached appears to fix this.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/469>
