[postgis-devel] [PostGIS] #471: Documentation errors against docbook 4.3 dtd
PostGIS trac at osgeo.org
Sat Mar 27 10:54:35 PDT 2010
 Reporter:  colivier         |       Owner:  pramsey
     Type:  defect           |      Status:  new
 Priority:  medium           |   Milestone:  PostGIS 1.5.2
Component:  postgis          |     Version:  1.5.X
 Keywords:  doc docbook dtd  |
 cd docs
 make check
 installation.xml:279: element command: validity error : Element emphasis
 is not declared in command list of possible children
 <term><command>--prefix=<emphasis>PREFIX</emphasis></command></term>
 installation.xml:301: element command: validity error : Element emphasis
                   <term><command>--with-
 pgconfig=<emphasis>FILE</emphasis></command></term>
 installation.xml:315: element command: validity error : Element emphasis
 geosconfig=<emphasis>FILE</emphasis></command></term>
 installation.xml:329: element command: validity error : Element emphasis
 projdir=<emphasis>DIR</emphasis></command></term>
 using_postgis_dataman.xml:368: element listitem: validity error : Element
 listitem content does not follow the DTD, expecting (calloutlist |
 glosslist | itemizedlist | orderedlist | segmentedlist | simplelist |
 variablelist | caution | important | note | tip | warning | literallayout
 | programlisting | programlistingco | screen | screenco | screenshot |
 synopsis | cmdsynopsis | funcsynopsis | classsynopsis | fieldsynopsis |
 constructorsynopsis | destructorsynopsis | methodsynopsis | formalpara |
 para | simpara | address | blockquote | graphic | graphicco | mediaobject
 | mediaobjectco | informalequation | informalexample | informalfigure |
 informaltable | equation | example | figure | table | msgset | procedure |
 sidebar | qandaset | task | anchor | bridgehead | remark | highlights |
 abstract | authorblurb | epigraph | indexterm | beginpage)+, got (CDATA)
 he best solution, in terms of performance and functionality
 available.</listitem
Ticket URL: <http://trac.osgeo.org/postgis/ticket/471>
