[postgis-devel] [PostGIS] #471: Documentation errors against docbook 4.3 dtd
PostGIS trac at osgeo.org
Mon Mar 29 09:57:39 PDT 2010
  Reporter:  colivier  |       Owner:  colivier
      Type:  defect    |      Status:  closed
  Priority:  medium    |   Milestone:  PostGIS 1.5.2
 Component:  postgis   |     Version:  1.5.X
Resolution:  fixed     |    Keywords:  doc docbook dtd
Changes (by kneufeld):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 This seem OK to me.  Good work Olivier.  Good thought with the xml
 validator make check rule you added.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/471#comment:2>
