[postgis-devel] [PostGIS] #465: st_makevalid segfault
PostGIS trac at osgeo.org
Tue Mar 30 03:47:47 PDT 2010
  Reporter:  pramsey  |       Owner:  strk
      Type:  defect   |      Status:  new
  Priority:  medium   |   Milestone:  PostGIS 2.0.0
 Component:  postgis  |     Version:  trunk
Resolution:           |    Keywords:  osx, opensuse
Changes (by robe):
  * keywords:  osx => osx, opensuse
Comment:
 I'm not sure if this is the same as my issue, but I finally successfully
 built on my Open SUSE 10.3 and got thru the make checks, but it crashes on
 the clean test.
 I'm running PostGIS trunk  and GEOS 3.3 and all pass until the last test
 the clean tests -- output of the error file looks like below
 ! RT|13.1|t|t|t
 ! RT|13.2|t|t|f
 ! RT|14|t|t|f
 ! RT|15|t|t|f
 ! RT|16.1|t|t|f
 ! RT|16.2|t|t|f
 ! RT|16.3|t|t|f
 ! RT|16.4|t|t|f
 ! RT|17.1|t|t|f
 ! PG|1|t|t|f
 ! PG|2|t|t|f
 ! PG|3|t|t|f
 ! SRID1|3
 ! SRID2|3
 ! SRID3|3
 --- 1,4 ----
 ! server closed the connection unexpectedly
 !       This probably means the server terminated abnormally
 !       before or while processing the request.
 ! connection to server was lost
Ticket URL: <http://trac.osgeo.org/postgis/ticket/465#comment:4>
