[postgis-devel] [PostGIS] #473: Can't compile at all under Windows
PostGIS trac at osgeo.org
Tue Mar 30 04:17:16 PDT 2010
  Reporter:  robe     |       Owner:  pramsey
      Type:  defect   |      Status:  new
  Priority:  medium   |   Milestone:  PostGIS 2.0.0
 Component:  postgis  |     Version:  trunk
Resolution:           |    Keywords:  mingw
Comment (by nicklas):
 without any further investigation compiling postgis trunk ended like this:
 lwout_wkb.c: In function `wkb_swap_bytes':
 lwout_wkb.c:130: error: `BYTE_ORDER' undeclared (first use in this
 function)
 lwout_wkb.c:130: error: (Each undeclared identifier is reported only once
 lwout_wkb.c:130: error: for each function it appears in.)
 lwout_wkb.c:130: error: `LITTLE_ENDIAN' undeclared (first use in this
 function)
 lwout_wkb.c:131: error: `BIG_ENDIAN' undeclared (first use in this
 function)
 make[1]: *** [lwout_wkb.o] Error 1
 make[1]: Leaving directory `/c/utv/src/postgis_trunk/liblwgeom'
 make: *** [liblwgeom] Error 2
 /Nicklas
Ticket URL: <http://trac.osgeo.org/postgis/ticket/473#comment:2>
