[postgis-devel] [PostGIS] #465: st_makevalid segfault
PostGIS trac at osgeo.org
Sun May 2 02:55:23 PDT 2010
  Reporter:  pramsey  |       Owner:  strk
      Type:  defect   |      Status:  new
  Priority:  medium   |   Milestone:  PostGIS 2.0.0
 Component:  postgis  |     Version:  trunk
Resolution:           |    Keywords:  osx, opensuse
Comment (by strk):
 robe, the valgrind log is good, but you need to build both GEOS and
 POSTGIS with debugging symbols (-g switch if using gcc).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/465#comment:13>
