[postgis-devel] [PostGIS] #297: [wktraster] Implement ST_DumpAsPolygons function for raster
PostGIS trac at osgeo.org
Mon May 3 12:09:29 PDT 2010
  Reporter:  mloskot    |       Owner:  jorgearevalo
      Type:  task       |      Status:  assigned
  Priority:  high       |   Milestone:  WKTRaster 0.1.6
 Component:  wktraster  |     Version:  trunk
Resolution:             |    Keywords:
Comment (by jorgearevalo):
 I think GDAL shouldn't be more difficult to compile on Windows than GEOS,
 for example. And GEOS is required. But I'm not a Windows developer. I
 can't ensure it. And ok... GEOS may be easier to compile, but the point is
 if we're going to compile WKT Raster against GDAL anyway...
 About Linux, I think most users will be able to compile the library, at
 least if they could compile PostGIS, or GEOS.
 The process is well documented here:
 http://trac.osgeo.org/gdal/wiki/BuildHints
Ticket URL: <http://trac.osgeo.org/postgis/ticket/297#comment:29>
