[postgis-devel] [PostGIS] #514: [wktraster] Some functions are missing in the XML reference
PostGIS trac at osgeo.org
Mon May 3 12:28:43 PDT 2010
  Reporter:  pracine    |       Owner:  robe
      Type:  defect     |      Status:  new
  Priority:  medium     |   Milestone:  WKTRaster 0.1.6
 Component:  wktraster  |     Version:  trunk
Resolution:             |    Keywords:
Comment (by robe):
 Pierre,
 Have these documented, but not sure how to break out the sections.  Broke
 some out.  Take a look and make suggestions.
 http://www.postgis.org/documentation/manual-svn/RT_reference.html
 Not sure where to put the value ones.  The only accessor we have is
 ST_Value and the others I would consider processing or output.  But its a
 bit of a grey zone.
 In the windows download - also have the wktraster_comments.sql (to install
 the help in PostgreSQL).
 http://www.postgis.org/download/windows/experimental.php
  Haven't added it as a make target in postgis yet.  Mostly cause not
 familar with that -- though it would follow the same routine as the
 postgis_comments just uses a different xsl file to generate.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/514#comment:3>
