[postgis-devel] [PostGIS] #297: [wktraster] Implement ST_DumpAsPolygons function for raster
PostGIS trac at osgeo.org
Mon May 3 12:45:47 PDT 2010
  Reporter:  mloskot    |       Owner:  jorgearevalo
      Type:  task       |      Status:  assigned
  Priority:  high       |   Milestone:  WKTRaster 0.1.6
 Component:  wktraster  |     Version:  trunk
Resolution:             |    Keywords:
Comment (by robe):
 Jorge,
 For your r5605 -- may I be so bold as to suggest you use ST_Union instead
 of ST_Collect.  ST_Collect may be faster but I think you will end up with
 many invalid polygons.  Though in this example ST_Union is faster (I guess
 because of the new cascaded union feature)
 For example
 -- Takes 4.2 seconds
 SELECT rid,ST_IsValid(ST_Collect(geom)) As geom
 FROM (SELECT rid, (ST_DumpAsPolygons(rast,1)).*
 FROM ch13.usdem WHERE rid = 1) As foo
 WHERE val <> 0
 GROUP BY rid
 Gives false
 -- Takes 3.8 seconds
 SELECT rid,ST_IsValid(ST_Union(geom)) As geom
 WHERE val <> 0
 GROUP BY rid
 Gives true
 to union the whole set above takes about 5 minutes.  It looks about right
 though and didn't give any errors.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/297#comment:33>
