[postgis-devel] [PostGIS] #516: Windows installer: Allow multiple DB authentication attempts (rather than failing to install)
PostGIS trac at osgeo.org
Mon May 3 17:26:42 PDT 2010
failing to install)
 Reporter:  mwtoews          |       Owner:  pramsey
     Type:  enhancement      |      Status:  new
 Priority:  low              |   Milestone:  PostGIS 1.5.2
Component:  postgis          |     Version:  1.5.X
 Keywords:  win32-installer  |
 When installing PostGIS on Microsoft Windows, the installer shows a
 "Database Connection Information" dialog to supply User Name, Password,
 and Port. The installer will begin to install PostGIS, however, if there
 is a mistake in the connection information, the installer fails part-way
 in, requiring it to be run again from the beginning.
 It would be nice to allow multiple attempts to correct the connection
 information, if say, there was a typo with the password. This way the
 installer only needs to be run once (for example, using Application Stack
 Builder, which downloads the installer to {{{%TEMP%}}}).
 Not only should the connection info establish a connection to a database,
 but {{{select count(*)=1 from pg_user where usename=$1 and
 usecreatedb;}}}. If there is an error, the user should be able to go back
 and correct, try again, repeat or cancel. Correct connection info should
 be established before starting the install process.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/516>
