[postgis-devel] [PostGIS] #517: ST_MakeEllipse geometry
PostGIS trac at osgeo.org
Tue May 4 04:40:53 PDT 2010
 Reporter:  Epzt         |       Owner:  Epzt
     Type:  enhancement  |      Status:  new
 Priority:  low          |   Milestone:  PostGIS 2.0.0
Component:  postgis      |     Version:  trunk
 Keywords:               |
 Dear all,
 I developed for my own needs a ST_MakeEllipse function.
 As it's name said, it returns a polygon with an ellipse shape.
 It takes 4 arguments:
 - the first is a point geometry on wich the ellipse will centered,
 - the second is the length of the main radius of the ellipse
 - the third is a percentage corresponding to the length of the ninor axis
 regarding the major axis length, i.e. minor axis length = major axis
 length x third argument
 - the fourth one is the number of points used to defined the polygon.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/517>
